Bug slicing a Surface with another Surface
No aplicable
Hey everybody,
I've already made a post about this, but happened again with 4 different computers, so I'm pretty sure it's a bug. However, someone from the forum was able to do it for me the other time.
I only need someone to do this simple command for me so I can finish this project for tomorrow. It would help me a lot!
First part:
1. Type SLICE, click on the first yellow surface.
Imagem inline 2
2. Click "S" (Surface) and select the big grey surface.
Imagem inline 3
3. Click enter. I need the small yellow surface under the grey big surface.
Second Part:
1. Same thing, but for the other side. Type SLICE and select the yellow surface.
Imagem inline 4
2. Type "S" (Surface) and select the small grey surface.
Imagem inline 1
3. Click enter. I need the small yellow surface under the grey one.
Marcos
0 Me gusta
Responder
Soluciones aceptadas (1)
605 Vistas
10 Respuestas
Respuestas (10)
Patchy
There is no Bug, 1 end doesn't intersect so it can't Slice.
0 Me gusta
No aplicable
So how did you do it, Patchy?
0 Me gusta
Patchy
As you described, SLICE pick the Yellow surface, enter, S for Surface, pick the gray and Enter, then Move the Yellow surface to see what it's done.
0 Me gusta
No aplicable
But I worked for you. What is in the picture is exactly what I'm looking for.
Could you do the same thing for the other side and send the file? It would help me a lot!
0 Me gusta
Patchy
The other end didn't work, it doesn't intersect, you need to redo the slicing surface.
I moved it a little and it sliced but I don't know how accurate you need it so I leave it un-sliced.
0 Me gusta
No aplicable
Actually I only need the front part, I can copy that little piece for the back side.
Could you send the file, please?
0 Me gusta
Patchy
I can't access to it, it's on another worker's PC.
If you attach the same dwg in 2007 version, maybe I can do it.
No aplicable
Here it is.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
the resulting drawing has > 200MB, so it's ZIPped and you have to unzip it before loading into AutoCAD.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
That's perfect, thank you so much, Alfred!
0 Me gusta
