AutoCAD Forum
Bug during Autocad 2019 opening
5 REPLIES 5
352 Views, 5 Replies
Hey everyone!
I have been experiencing the following issue lately:
whenever I try to open Autocad 2019 I simply get the following message:
"All of the possible directories for storing temporary files either do not exist or are readonly. Please correct this situation before running AutoCAD again" with only one option ("OK");
Apparently, AutoCAD does not open and I do not know what to do!
Any ideas?
5 REPLIES 5
pendean
john.vellek
Hi @Anonymous,
This is an error caused by the OS.  The only reliable fix that I have seen is to create a new Windows user profile.  This is also mentioned in the article that Dean kindly provided.
John Vellek
in reply to: john.vellek
thank you for the rapid reply! I started reformating the whole pc - do you happen to know why does AutoCAD do this when switching user profiles? Is there some way to dodge it?
in reply to: pendean
Thank you so much for the help. Do you happen to know if a corrupted user profile equals a system virus infection? Or it might as well be any other reason?
john.vellek
HI @Anonymous,
A total rebuild is not necessary but it will give you a nice clean computing environment.  A new user profile is usually all that is required to get thing back up and running.  I have not done a lot of personal research on the issue but it is not a virus and it does affect other applications other than Autodesk ones.
John Vellek
AutoCAD Inside the Factory
