breakatpoint fails to get right osnap
With the break at point command, the program doesn't behave correctly. When I specify midpoint it still picks endpoint. I then manually specify midpoint, not via osnap. When I copy the object to an empty drawing and do exactly the same thing it works fine. With some lisps I also get the message 'too many intersects for objectsnap' or similar. It's not a large drawing as such but it does have 40 xrefs loaded. I always keep only the layers I need visible, which is about 1/30th of the total. It seems to me there's some kind of object overflow? Moving the UCS so the break point is closer to the origin doesn't help either.
unloading 39 xrefs does not fix it. detaching 39 xrefs does but that is very much NOT the way I want to go.
