BREAK multiple lines at the intersection of another line and find CENTERLINE
Question 1) I have multiple lines that needed to be broken with out a gap. How to do this?
Need to break all green lines into separate lines at the middle yellow line. I need to extract the bottom half of lines and then the top. How can I do this? BREAK command isn't great. Thanks
Question 2)
How can (using same image as about) find a common line that falls between the top white line and the bottom yellow line to create a middle line or centerline (average) that I can edit. Is it possible? I am trying to make in fill contours and I have offset but then they look too similar to the line I just offset. Is there a command to do such? If I use the CENTERLINE command it breaks up my polyline into small individual segments but I need the whole line.
