Anuncios
Break at Point
Break at Point
No aplicable
as showing in the attached image, few continuous lines are flowing on panels, now I want to create individual files for each rectangular box with the green lines  on it. I tried using "Break at Point" it is taking very long time to break the lines at every junction. Any easy ways?Issue.PNG
0 Me gusta
Responder
813 Vistas
8 Respuestas
Respuestas (8)
No aplicable
There's a lisp on www.swamp.org that might be useful - lots of different options for breaking objects at intersections.
You'll need to register for the website but it's free.
Break lisp
Breaking lines shouldn't normally take very long though - is this drawing particularly slow when you're doing other things or is it just breaking that's slow?
3wood
Are these panels rectangle polylines?
0 Me gusta
pendean
Community Legend
Community Legend
@Anonymous wrote:
now I want to create individual files for each rectangular box with the green lines  on it. Issue.PNG
Why not use BOUNDARY command? Look up usage in HELP.
0 Me gusta
No aplicable
Hi marianne.mcdonald,
Thanks for your reply. i will try the software you mentioned.
for this current job I have to cut each junction of green line and rectangle for this job alone I have to use Break at Point command around 400 times, i believe this could be done bit easily.
0 Me gusta
No aplicable
Yes they are rectangular poly lines.
0 Me gusta
No aplicable
Hi
0 Me gusta
pendean
Community Legend
Community Legend
How? I'm curious now about that conclusion :cara_con_una_leve_sonrisa:
0 Me gusta
3wood
What do you mean "individual files"? Like WBLOCK out the rectangle and the green line out as a separate dwg file? Then what is the file name pattern? "Rectangle1.dwg"?
0 Me gusta
