Break a polyline wall and close the sides with a polyline
No aplicable
i have to make lots of floorplans, for example:  i start with the the outside wall, I offset this polyline and close it with 2 polylines at each side.
after i have made the wall all around the floorplan I will have to put in the windows, doors ect, but they are not made with a wipeout frame, i am not allowed to use this, so i have to break the polyline walls and place the door, and again i would have to connect the pl's  again with 2 pl's at each side so the pl's are closed  again.  is there an easier way to do this of a lisp or something that would speed up my drawings?
0 Me gusta
Responder
Soluciones aceptadas (1)
990 Vistas
5 Respuestas
Respuestas (5)
imadHabash
The way here is to explode your polylines then make one window and start copy it all around and trim the wall lines beneath . In this way you don't have any overlapped lines and you don't have to make extra works with reconnecting polylines that have no advantages to keep it .
Imad Habash
0 Me gusta
BeKirra
IMO op would have issues when hatching the walls on the floor plan.
@Anonymous suggest you ask some one in your office if they have any add-on that can help. It may save your time.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
pisal1996
Solución aceptada
I suggest to draw by rectangle using command "REC"
0 Me gusta
Alfred.NESWADBA
You can already add these "room closing polylines" as well as the "wall closing polylines" inside the door block.
Then you can add hatches for walls as well as for rooms without issues.
If you need day-in day-out walls/doors/windows/rooms/.... then think about using AutoCAD Architecture. If you are on subscription then AutoCAD Architecture is part of the AutoCAD toolsets and you can install and use it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
Kent1Cooper
Go over to the >Customization Forum< and do some Searching for combinations of relevant terms, such as "break doors," to find routines that will do this kind of thing.
Kent Cooper, AIA
0 Me gusta
