@Anonymoushello, just in command prompt FILLET between two lines or circle (set fillet radius to zero). thanks
i don't know how did you prepare your drawing ( from AutoCAD or imported from other software ) !! your drawing is consist from mini attached lines even at arc areas !!! this is not right you must have Lines,Arcs and splines maybe if needed . what i want to say is to redraw your lines more accurately and with arcs ( where needed ) . improve the way that you're follow to draw and improve your technique . ![]()
All the best,
Imad Habash
