Boolean subtract - Holes through multiple materials
No aplicable
I have a sandwich of materials of different materials and hence different colours and wish to make a hole through them. For an example i have a sandwich of three sheets of material, red, green and blue through which i want to make a hole.
I create the three sheets, as boxes, on one layer and change the colour property of the layers to red, green and blue. I then create a cylinder. The model is shown as, "basic sandwich plus cylinder".
I undertake a boolean subtract of the cylinder from the three layers and the result is that the three sheets become one one blue solid with a silver hole, the colour of the cylinder. See "Sandwich with hole". From searching the web this is what i would expect but is not what i want.
I want the three sheets to retain their own properties and the hole in each to be the colour of the sheet.
The work around i have is to create three cylinders each the same colour as one of the sheets and undertake three boolean subtracts.
The problem i have is greater than this as i have an array of say 30 holes through a sandwich of five different materials. My work around takes ages as i have first to copy the array to the same location 4 times, explode the array, and then perform 150 boolean subtracts!
There must be a simpler solution as in the aerospace industry this must be a daily task.
Any help appreciated.
Bob
0 Me gusta
Responder
Soluciones aceptadas (1)
695 Vistas
8 Respuestas
Respuestas (8)
Patchy
It was made that way if you use SUBTRACT.
To get around this, you explode the cylinder to get a surface, then use command SLICE and pick the Surface option, this way the sheets still remain separated.
0 Me gusta
JDMather
Can you create
1 box
1 cylinder and array the cylinder
Subtract
Slice the box into layers?
Or simply create a thinner box and copy it after "drilling"?
I suspect your layers must be something more complex than the example you attached here.
0 Me gusta
JDMather
@Anonymous wrote:
...There must be a simpler solution as in the aerospace industry this must be a daily task.
I doubt that the aerospace industry is using AutoCAD for this.
Since I have brought up the topic of software used - this is trivial in Autodesk Inventor.
No aplicable
Thanks for the speedy reply.
I exploded the solid cylinder and sliced it twice at the level of the junction of the three sheets.
How do i them make the hole using the sheets and the sliced surface of the cylinder?
0 Me gusta
No aplicable
You are correct the problem is more complex as the sheets are not all the same size but i thought if i had a solution to the simple problem i could work the rest out for myself.
i tried your method but the array cannot be subtracted and has to be exploded first and if do I still get silver holes inside the coloured sheets.
0 Me gusta
No aplicable
I don't have Autodesk Inventor and therefore can't use that. Like lots of things in life if i didn't have to start from here i wouldn't; but that's where we are.
0 Me gusta
Patchy
Solución aceptada
Slice, pick all three sheets, then S for surface,pick the surface of the cylinder, enter, pick the sheets, and move the punched out parts.
JDMather
@Anonymous wrote:
I don't have Autodesk Inventor and therefore can't use that. ....
Autodesk Fusion 360 is very very inexpensive (not sure how it would do with this problem though.
But I have to imagine it would be easier than AutoCAD.
0 Me gusta
