- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Everyone,
I am facing a problem that may have a simple solution that I am not aware off.
I am entrusted to create as built drawings from the original construction drawings provided to me in a pdf format.
Using Auto Cad LT software, I have two options:
1. Import the construction drawing as a pdf.
2. Do a PDF to DWG conversion and use that instead.
As these drawings are extremely detailed, and with few changes to make, I prefer option 2, that way I won't have to trace the entire drawing which would be inefficient, time consuming and more prone to error (missing out subtle details).
The problem however, is that upon conversion to DWG, the texts in the drawings gets altered and are no longer sharp and crisp (see attached image). This also seems to be the case with lines in the drawing that now appear broken (which is an easy fix to be honest). The problem remains when I convert the modified DWG back to PDF.
To make a long story short, I would prefer to work with a DWG file, and would be very grateful if anyone out there could provide me a solution to this query.
Thank you.
