Bluebeam batch plotting problem
PascalJ_87210
Message 1 of 19
PascalJ_87210
I am trying to generate a batch plot within Autocad 2017 using Bluebeam and I get the attached error when I am trying to open the Autocad DST file to add files to the batch plot.
It has happened on 2 different projects I have been working on today.
I have done this tens of times. I never had a problem until today.
I have contacted Bluebeam and they referred me to Autodesk.
I dont recall making any changes to the software. Not sure what would cause the problem.
Suggestions?
Replies (18)
Message 2 of 19
pendean
Community Legend
Community Legend
has this ever worked before today?
Or is BlueBeam new? Or something else is new?
Does this work if you don't use BLUEBEAM, just the built-in PDF drivers?
Any reason you don't want to click on that DETAILS button so can understand more about the reason for this crash? If there is a scroll, you need to post all the info.
Message 3 of 19
PascalJ_87210
These are the details for the error:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040111): Creating an instance of the COM component with CLSID {DC1C5A9C-E88A-4DDE-A5A1-60F82A20AEF7} from the IClassFactory failed due to the following error: 80040111 ClassFactory cannot supply requested class (Exception from HRESULT: 0x80040111 (CLASS_E_CLASSNOTAVAILABLE)).
at System.Windows.Forms.OpenFileDialog.CreateVistaDialog()
at System.Windows.Forms.FileDialog.RunDialogVista(IntPtr hWndOwner)
at System.Windows.Forms.CommonDialog.ShowDialog(IWin32Window owner)
at Bluebeam.SDK.Batch.BatchWizard.ᐂ(Object , EventArgs )
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3260.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 21.0.0.0
Win32 Version: 21.0.104.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL
adui21
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL
AdUiPalettes
Win32 Version: 21.0.52.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
Win32 Version: 4.7.3314.0 built by: NET472REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Configuration
Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
Win32 Version: 2015.11.1.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL
AdWindows
Assembly Version: 2015.11.2.0
Win32 Version: 2015.11.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL
WindowsFormsIntegration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Classic
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.classic/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.classic.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationFramework.Aero
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationUI
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
UIAutomationTypes
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
ClicJsInfoCenter
Win32 Version: 3.1.26.0
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/CLM/V3/MSVC14/ClicJsInfoCenter.dll
AcLivePreviewContext
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayer.resources.DLL
AcMr
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcMr.DLL
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
BIM360GlueAutoCAD2017Addin
Assembly Version: 4.37.6853.0
Win32 Version: 4.37.6853.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAutoCAD2017Addin.dll
BIM360GlueAddinsCommon
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAddinsCommon.DLL
log4net
Assembly Version: 1.2.11.0
Win32 Version: 1.2.11.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/log4net.DLL
FeaturedAppsPlugin
Win32 Version: 21.0.46.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2017/Win64/FeaturedAppsPlugin.dll
PbPDF for Acad 21 Addin
Assembly Version: 16.5.6155.20138
Win32 Version: 16.5.6155.20138
CodeBase: file:///C:/Program%20Files/Autodesk/ApplicationPlugins/Bluebeam%20Software/2016/PbPDF%20for%20Acad%2021%20Addin.dll
Bluebeam.Interop.acad
Assembly Version: 16.0.5925.18419
Win32 Version: 16.0.5925.18419
CodeBase: file:///C:/Program%20Files/Autodesk/ApplicationPlugins/Bluebeam%20Software/2016/Bluebeam.Interop.acad.DLL
PbPDF for Acad 21 Tasks
Assembly Version: 16.5.6155.20137
Win32 Version: 16.5.6155.20137
CodeBase: file:///C:/Program%20Files/Autodesk/ApplicationPlugins/Bluebeam%20Software/2016/PbPDF%20for%20Acad%2021%20Tasks.DLL
Bluebeam.Utilities
Assembly Version: 16.5.6155.19873
Win32 Version: 16.5.6155.19873
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Bluebeam.Utilities/16.5.6155.19873__0c673d50796bb708/Bluebeam.Utilities.dll
Bluebeam.COM.Interfaces
Assembly Version: 16.5.2.33
Win32 Version: 16.5.2.33
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Bluebeam.COM.Interfaces/16.5.2.33__0c673d50796bb708/Bluebeam.COM.Interfaces.dll
BluebeamPbPub
Assembly Version: 16.5.6155.19912
Win32 Version: 16.5.6155.19912
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/BluebeamPbPub/16.5.6155.19912__0c673d50796bb708/BluebeamPbPub.dll
Bluebeam.Core.Utilities
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Bluebeam.Core.Utilities/16.5.2.33__0c673d50796bb708/Bluebeam.Core.Utilities.dll
Bluebeam.Core.Registration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Bluebeam.Core.Registration/16.5.2.33__0c673d50796bb708/Bluebeam.Core.Registration.dll
Bluebeam.Windows.Utilities
Assembly Version: 16.5.6155.19885
Win32 Version: 16.5.6155.19885
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Bluebeam.Windows.Utilities/16.5.6155.19885__0c673d50796bb708/Bluebeam.Windows.Utilities.dll
Bluebeam.Windows.Registration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Bluebeam.Windows.Registration/16.5.6155.19885__0c673d50796bb708/Bluebeam.Windows.Registration.dll
BluebeamSDKComBridge
Assembly Version: 16.5.6155.19920
Win32 Version: 16.5.6155.19920
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/BluebeamSDKComBridge/16.5.6155.19920__0c673d50796bb708/BluebeamSDKComBridge.dll
Bluebeam.Brewery
Assembly Version: 16.5.6155.19908
Win32 Version: 16.5.6155.19908
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Bluebeam.Brewery/v4.0_16.5.6155.19908__0c673d50796bb708/Bluebeam.Brewery.dll
PbPDF Dynamic Acad
Assembly Version: 16.5.6155.20038
Win32 Version: 16.5.6155.20038
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/AutoCAD/PbPDF%20Dynamic%20Acad.dll
System.ServiceModel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Bluebeam.Core.Graphics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Bluebeam.Core.Graphics/v4.0_16.5.2.33__0c673d50796bb708/Bluebeam.Core.Graphics.dll
Bluebeam.Core.PDF
Assembly Version: 16.5.6155.19882
Win32 Version: 16.5.6155.19882
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Bluebeam.Core.PDF/v4.0_16.5.6155.19882__0c673d50796bb708/Bluebeam.Core.PDF.dll
Bluebeam.Windows.PDF
Assembly Version: 16.5.6155.19886
Win32 Version: 16.5.6155.19886
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Bluebeam.Windows.PDF/v4.0_16.5.6155.19886__0c673d50796bb708/Bluebeam.Windows.PDF.dll
Bluebeam.Fonts
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Bluebeam.Fonts/v4.0_16.5.2.33__0c673d50796bb708/Bluebeam.Fonts.dll
CustomMarshalers
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/AutoCAD/PbPDF%20for%20Acad%2021%20Addin.dll
AcadConversionSettingsTab
Assembly Version: 16.5.6155.19946
Win32 Version: 16.5.6155.19946
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/Tabins/AcadConversionSettingsTab.dll
AcadPageSetupTab
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/Tabins/AcadPageSetupTab.dll
PDFSecurity2Tab
Assembly Version: 16.5.6155.19969
Win32 Version: 16.5.6155.19969
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/Tabins/PDFSecurity2Tab.dll
BookmarksTab
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/Tabins/BookmarksTab.dll
TextStampExTab
Assembly Version: 16.5.6155.19949
Win32 Version: 16.5.6155.19949
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/Tabins/TextStampExTab.dll
FileAttachTab
Assembly Version: 16.5.6155.19948
Win32 Version: 16.5.6155.19948
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/Tabins/FileAttachTab.dll
DigSigTab
Assembly Version: 16.5.6155.19947
Win32 Version: 16.5.6155.19947
CodeBase: file:///C:/Program%20Files/Bluebeam%20Software/Bluebeam%20Revu/2016/Pushbutton%20PDF/Tabins/DigSigTab.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
ContextualTabSelectorRules
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Microsoft.Expression.Interactions.DLL
PresentationFramework.Luna
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcAeNet.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcAeNet.resources.DLL
AcCloudRender.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcInterfere.resources.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcScaleList.resources.DLL
AcSeamless.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL
AcUnderlay.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCalcUi.resources.DLL
UIAutomationProvider
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcMrUI.DLL
Autodesk.AutoCAD.Interop.Common
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Autodesk.AutoCAD.Interop.Common.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Autodesk.AutoCAD.Interop.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Message 4 of 19
pendean
Community Legend
Community Legend
Has Bluebeam ever worked before now?
Or is that new? Or did you get a new PC?
Your Windows and/or your Anti-Virus and/or your Internet Browser/Security settings changed: AutoCAD (and other applications) cannot reset it for you, you have to find the culprit and turn it back down or off. Usually if you upgraded to a new PC or a new webbrowser or finally turned on that firewall, or it could be triggered by a new software installation.
Or video card driver or Windows update.
So what's new with your setup?
Message 5 of 19
PascalJ_87210
The only change I can think of is installation of the new Windows 10 version 1809. Did that on Friday. Do you think that may be the culprit?
Message 6 of 19
RobDraw
Please answer all of the questions. The key one is: Has this ever worked before or are you trying this with BlueBeam for the first time?
What procedure are you using to generate this batch plot? It could be in the procedure.
Rob
Message 7 of 19
PascalJ_87210
I have used bluebeam batch plot with Autocad hundreds of times. I use it every day.
Never had that problem before. Last major change done on my computer was to update to latest windows 10 version 1809. I do not know if this related.
In Autocad, I just go to the Bluebeam menu and click Batch plot.
After choosing the destination folder and the name of the batch file, i get the error when trying to add files by selecting the DST file. This is the procedure I follow every time.
Message 8 of 19
RobDraw
Does it happen with all DST files or just this one?
Does it work if you create a new DST file?
I have seen Windows updates have unexpected effects on printing. I don't know if this one did or not.
Rob
Message 9 of 19
pendean
Community Legend
Community Legend
And why did you never mention this before LOL
Now we know your actions are the reason: hope we can fix this: let's start
Did you wipe your PC harddrive clean (aka format it), install Windows10, get it fully patched and updated, then install all of your software as if for the first time ever?
or something else took place?
Is your Windows log-in full admin level, or are you in an office with a Server and IT department?
Message 10 of 19
PascalJ_87210
Happens on all DST files, old and new.
Message 11 of 19
PascalJ_87210
I just updated windows. No formatting or reinstalling programs.
I have limited admin level. We have a remote IT department.
Message 12 of 19
RobDraw
Unfortunately, I do not have BlueBeam to test anything. So, my help is going to be guesswork. Hopefully, someone else reads this that does have BlueBeam and the update.
Can you (or IT) roll back the update to see if that is indeed the cause?
Also, check the BlueBeam forums to see if anyone else is having the same issue. Sorry, but those have been closed.
Rob
Message 13 of 19
pendean
Community Legend
Community Legend
You will need to contact and work with your IT, this is a system level issue: you will need to reinstall all of your Autodesk/Bluebeam software and they need to resolve your security crash access problems.
Most likely they will want to reformat your PC to remove all the gremlins you introduced to the system, but that''s up to them.
Message 14 of 19
RobDraw
@pendean, I think you may be misundersting. The OP did not upgrade to Windows 10. He is referring to the recent update that was rolled out. Everything "should" work fine but, as we all know, sometimes they don't and we need to wait for a fix or roll back to the previous update.
Rob
Message 15 of 19
PascalJ_87210
I rolled back to the previous windows version and the problem is now fixed.
Message 16 of 19
pendean
Community Legend
Community Legend
I could have sworn the wording was different when I replied... Looks like the OP found and shared fi.
Message 17 of 19
RobDraw
I'm not so sure anymore. It looks like the OP solved it himself.
Rob
Message 18 of 19
We also have issues with Bluebeam plug in in AutoCAD Electrical 2019. Bluebeam is not displaying in the menu bar, the only way to get Bluebeam going now is by typing: BSIBATCH in the command line.
Message 19 of 19
RobDraw
You should start a new thread. Your issue is different and the solution for this thread would not solve your problem.
Rob
