Blocks with attributes
builder7772001
builder7772001
I've been working with attributes inside of blocks. After inserting the block and filling in the attributes, the text appears very large.  I haven't found a way to get the text to scale to the right size. I even tried ATTSYNC.
Please advise
Doug
0 Me gusta
Responder
364 Vistas
5 Respuestas
Respuestas (5)
ChicagoLooper
How are you ‘filling in the attributes?’ Would it be possible to upload screenshots that capture the places where you enter the attributes?
Typically the attributes are entered or filled in a dialog window named Enhanced Attribute Editor.
Entering the attributes in the enhanced block editor will maintain the text height designed by the block’s author. If you are modifying the parameters of the block (in the block editor) or inputting your attributes somewhere other than the enhanced block editor then it could be the reason why your text is too tall.
Chicagolooper
0 Me gusta
builder7772001
This is after inserting the block with the attributes.
This is after selecting the block and choosing to edit the attribute under text options - the height is grayed out.
The text is one that I set up
This is the text style that I set up for the title block. The paper text height was set at 3/32"
Thanks for you input
Doug
0 Me gusta
3wood
Try remove "Annotative" from the text style.
ChicagoLooper
Hello @builder7772001
Your Text Style named MyText has a Paper Text Height of 0'-0 3-3/32". Change this value to 0.00.
Chicagolooper
0 Me gusta
builder7772001
I'll try that
0 Me gusta
