Blocks with Attribute Text - Polyline and Text displays badly when not connected to docking station
jlembo73DHJ
jlembo73DHJ
Good day all;
I have a challenge for the collective.  I have blocks that have been created using rectangles and pentagons with some single line text, and some attribute text.  These blocks generally speaking work perfectly fine but, one of my sales people who has Autocad on his machine needed to use these out in the field.  While the laptop was plugged into the docking station, the blocks looked perfectly fine.  Once the laptop is unplugged from the docking station, you only see the corners of the rectangle and pentagon and the attribute text appears almost "pixelated".  Has anyone seen this issue or know of a setting that may affect these blocks?
Autocad 2024 running on a new HP gaming laptop
Images and .dwg attached.
cadffm
I guess your product is not up2date.
Share your Productname and Productversion, command: ABOUT
TEST:
Turn LWDISPLAY off
or Set GFXDX12 off (0) and restart Acad
You should tell about your productname and productversion. Uncutted Screenshots offers also more informations than cutted.
Sebastian
pendean
Community Legend
Community Legend
An unplugged laptop these days goes into battery-preservation-mode and scales back dramatically anything that is designed to drain the battery, like processor and more importantly better graphics cards etc.
Now that you know that: have them turn off GFXDX12 (requires a program restart), maybe even turn off hardware acceleration in GRAPHICSCONFIG command.
Then explore the laptop settings to run hot at maximum, and/or reach out to the Laptop Manufacturer Support and see what they offer s workaround to prioritize draining the battery and running at full tilt (may not be an option for that model).
jlembo73DHJ
Thanks for that.  I added some of the basics.  Will have my guy try that fix
jlembo73DHJ
Thanks for the suggestion.
Graphics config looks normal. Will try the other fix
