Anuncios
Blocks on Toolpalettes not working.
rhoscadman
rhoscadman
Hi Folks,
Have recently bought a new laptop and have tried to transfer all my Toolapelettes from the old machine to the new one. But even though I have re-pathed the location of each item in each *.xtp file, the block will not show an icon on the toolpalette nor can I insert it into the drawing.
So now I have to run through the "right click >> select...>> find source file>>ok for each and every item. There are hundreds of them.
I have done the "find/replace" routine on notebook for all the *xtp file but unless I do it manually as described in previous paragraph, it doesn't work.
Any ideas?
Many thanks.
0 Me gusta
Responder
527 Vistas
10 Respuestas
Respuestas (10)
cadffm
if you open the properties to repath,
is the path right or old? No typo?
.xtp files are just transfer. The used files are  .atc (after or import).
And there, I do a find&replace
Sebastian
0 Me gusta
rhoscadman
tHANKS BUT NO-GO......IT DOESN'T WORK
0 Me gusta
pendean
Community Legend
Community Legend
What doesn't work please ? You never say what you tried, @cadffm was asking for more details and providing general guidance.
Did you by chance only do this https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-export-and-...
What are the full file paths your TP blocks are looking for exactly?
And how does that compare to the full File Repath you are doing manually for one of them?
And which of those full paths are listed in the Search Paths list in OPTIONS command's FILES tab?
0 Me gusta
cadffm
 stilk working, there must be an (special?) Issue on your side.
Sebastian
0 Me gusta
rhoscadman
I tried the repath name in atc files using find/replace in notebook. THAT didn't work.
Checked for typos, but all correct.
I have placed all my palettes in a specific location in my "documents" folder, for ease of access. So I used the file locating path to repath them. So basically, I only had to change one word in the path to point the link in the correct location. Some of the .xtp files picked up the new location, most didn't.
Unfortunately I did not use the export/import facility as I had initially trierd to use MS Onedrive to transfer everythink on my laptop in toto. but it kept mislaying the toolpalette files. So I ultimately had to cancel Onedrive and continue with share files feature.
The paths in the .xtp files are exactly as written when I repath them individually.
Yes the Palette files location are registered in OPTIONS >> FILES.
0 Me gusta
cadffm
>>"Some of the .xtp files picked up the new location, most didn't."
If you talk about the content in .xtp
that was your turn (you tried a find&replace).
If not all pathes correct, you had a problem with your find&replace.
I miss one more information:
After import o e of the .xtp files (where you had successful f&r):
The file path is correct (insertion tool property Path) and is working or not?
'Documents' is a special animal, but if you used the full path c:\users\.. I expect it should work as it did 1000 times before.
Sorry, without the data, I can't help more.
(For a test, you can copy your .dwg to c:/temp/test or another local folder without special characters
and run a new test with the original .atc files.
This MUST work well.
Sebastian
0 Me gusta
cadffm
OPTIONS >> FILES>> Toolpalette path
Abd inside this folder is the catalog .atc file and subfolder /palettes
where your palette .atc are.
And the subfolder Images, with the thumbails.
Sebastian
0 Me gusta
rhoscadman
Thanks for your help. Just a small question: what does a .atc file actually do? I found a whole bunch of them in a folder called "Palettes" and opened a couple, and the paths were completely wrong. So I did a S&R on a couple, but unsure whether I should continue spending a lot of time repalcing the correct path in ALL of them?
In answer to your question, after deleting the .xtp file and doing a S&R on all the block paths and saving the file I then imported the palettebut it STILL doesn't bring in the block. So I selected the item in the ToolPalette, selected properties, and the path is correct but no icon of the block. See 1st attachment!!
Yes, I know, I have always dne my work in a specific company folder which I save into my "Documents" folder. When work is complete, I copy and paste into my company's server. I have been doing this for 3 years as I work remotely so "Documents" is not the problem.
0 Me gusta
pendean
Community Legend
Community Legend
@rhoscadman wrote:
Thanks for your help. Just a small question: what does a .atc file actually do?...
0 Me gusta
cadffm
the one "catalog" atc in your toolpalette path, is the index/catalog file.
- What palettes have to load.. and more settings
All .atc in in /palettes subfolder are the palettes themselve! This is where the content of a palette is defined.
This is where the (right) pathes have to be.
- That's why you can see the wrong path in your tool-properties. The .atc file is where the tools are defined.
>So I did a S&R on a couple, but unsure whether I should continue spending a lot of time repalcing the correct path in ALL of them?"
-I need just ONE s&r to change all path in all file.
Pimp your skills about Texteditors / search another one who can do a s&r in multiple files. Out there, are a lot of powerful editors & others tools.
- Icon, this is not priority one, but one try:
You can't see the Icon in your palette ? (In your screenshot we can see it)
Perhaps palette and the property dialog use different source (untested) and the icon for palette display is not there or just bad.
Icons are stored Images folder, the other subfolder in your toolpalette path.
OR, your data is completely confused because of many tries and fails (I can't check the whole stuff on your side).
- Bad place, if you don't use the same (windows) UserID or if the location  in your company for this stuff is another.
But if you know how to handle and edit all things, okay.
(You should know it first, then you use, wrong order in your case ;D )
- Ahh okay. Perfect, until you have to move it to another location.
At THIS moment I would write
What I would recommend (how to "renew" it cleanly once),
but sorry, I don't have time for it now.
Sebastian
0 Me gusta
