Blocks in Xref Printing Solid
05:26 PM
I'm working on 3 different DWG's in this area. 2 of them print out to PDF just fine, but in this DWG, these particular blocks (see attached photos) keep printing solid black. I've made changes to the xref layer, the layer for the block inside the xref, ect. Interestingly, if I copy and paste the same block into the host DWG, it prints out fine. Something about the block in that particular xref, in this particular host drawing is causing issues and I can't figure it out. Oh and all 3 DWGs use the same print setting and pent tables, so I don't believe that is the cause. Also an Etransmit is attached if needed. Thanks for looking!
