Blocked Part of Model Screen Issue in AutoCAD DWG File
Mohamedhamdyacc0
Mohamedhamdyacc0
Greetings all,
I'm facing an issue in AutoCAD where the right side of my model screen is blocked, preventing me from moving my crosshair to that area. It seems like I'm working with only half of the screen. This problem occurs only in a specific DWG file, while others work fine. I've checked the viewport configuration and it's set to "SINGLE." I've attached a screenshot for reference.
I've tried troubleshooting by reviewing the viewport settings, but haven't found a solution. Any guidance or clarification would be greatly appreciated.
Thank you for your time and support.
ennujozlagam
there could be a hidden objects in that space? check you layer properties or check your limits?
Valentin_CAD
@Mohamedhamdyacc0 ,
Are you able to click on the right side?
Try selecting another Viewport Configuration and then switching back to Single.
Otherwise your drawing may be corrupted and requires optimization.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Mohamedhamdyacc0
Thank you for solving my AutoCAD issue! Your help was greatly appreciated
