Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
blocked image not clipping correctly in autocad
binuntachari
binuntachari
i have a blocked imge for pattern. i try to clip that, it is not cliping correctly. i attached dwg below. i show the border i want. please help me about this issue.
can any one clip that correctly? & can u please tell me how to solve the issue
before cliping👆
after cliping
Valentin_CAD
@binuntachari ,
Consider separating the image and pattern into two different drawings.
You will need to use the XCLIP command and IMAGECLIP as needed.
See quick sample Zip file.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
binuntachari
like that its okay. but the background image stretched too much
Valentin_CAD
@binuntachari ,
You will need copy the image and clip as needed.
The information provided should guide you to complete your goal.
Emilio Valentin
