block - table 2017 - 2024
callewaert_pauwels
Message 1 of 8
callewaert_pauwels
Hello;
I Have a new version of autocad 2024 recently;  i have a library made of my own in  autocad 2017 with drawings linked with a table with mesurments;  if i stretch,  the mesurments change in the table;  however in the new version 2024 when i stretch;  the measurments stay the same;  does anywone have an idee?
Replies (7)
Message 2 of 8
cadffm
Hi
share one sample (.dwg) please, nobody can know for sure what you have - just guessing.
Sebastian
Message 3 of 8
jayhar
  • Ensure that the fields used in the table cells are set to update automatically. Fields are placeholders in AutoCAD that display data, and they need to be set to update automatically.
  • Check the properties of the cells containing measurements in your table, and verify that the field update setting is set to automatic
Upload CAD File please for  references...............
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 4 of 8
callewaert_pauwels
Hello;
dwg in upload;
the properties of the cells?  i only find the properties of the table
thank you for replying
Message 5 of 8
jayhar
Check This Cad File, its Working, i Just do WBLOCK.
Message 6 of 8
callewaert_pauwels
Jayhar;
It works; but when i make it a Wblock and insert it again it doesnt work anymore;
Do you have an idee with variable or adjustment it could be?
Message 7 of 8
callewaert_pauwels
Jayhar;
I tested somethings between the version 2017 and 2024;  I'm sure the problem lies in the insertion of the block not the Wblock;  the block made in wblock 2024 version  works after "insert" in 2017 but not in the 2024 version.
Message 8 of 8
callewaert_pauwels
Jayhar;
It works !!!!!!!!!!!!!!!!!!!!!!
apparently they changed the command Insert in 2019 but it can be restored to the classic insert command
How to restore the classic Insert command in AutoCAD 2020 and later (autodesk.com)
Thanks for the help:
