08:59 AM
Is there an efficient way to replace an existing block with a new block that is not defined in the drawing in one command?
I am trying to script a title replacement across a big set of drawings. The current drawing contains "title-old" and I'd like to replace it with "title-new" that is not yet inserted/defined in the drawing. The names of the blocks are different, I can't change that. I can do this with a few steps, but it's messy (insert first in some place to the side, then replace, then delete the bogus insert).
I would like to simply say "insert path\title-new in place of title-old" somehow.
I'm using -INSERT and -BLOCKREPLACE. Maybe there is a better way?
Thanks!
