Block Insert command
jamied2000
jamied2000
I want my AutoCAD 2021 to automatically pull up the dialog box that I have circled in the attached pic.  What command do I have to assign to my "I" in order for this to come up?  At the current time I have "I" assigned to "insert" command and it pulls up the blocks palette instead of the second attached dialog box.
Patchy
rkmcswain
Add this to your acaddoc.lsp file. If you don't have this file, create it and put it in a folder such as C:\CADSTUFF, and then add this path to the TOP of your support file search path.
(defun c:i ()(princ "Macro: Insert ")(progn (initdia)(vl-cmdf ".-insert" "~"))(princ))
R.K. McSwain     | CADpanacea | on twitter
Kent1Cooper
Try the attached InsertDwgAsBlock.lsp with its IDAB command.  It opens up the file navigator in the current drawing's folder, but you can pick the pull-down and navigate to anywhere you want to select a drawing file, which it will use in an Insert command, leaving you to complete that [insertion point, scales, etc.].
If that does what you want, its command definition can be substituted for the standard INSERT command, but I'd be reluctant -- do you really want INSERT to always bring up a drawing-file navigator, rather than the regular Block dialog?  Or change my command name to I, remove I as the alias for INSERT, and use it for this purpose, and you'll need to enter more of the command name to get INSERT?
Kent Cooper, AIA
