AutoCAD Forum
Block image not showing up
2 REPLIES 2
NowakA09
1692 Views, 2 Replies
We have a block that somehow was inserted into many of our drawings.  The block name is layers.  When I use Quick Select to identify where the are in Model Space it shows the grips but no image.  When I exit the Quick Select command to then try selecting the block with a crossing pattern, there's nothing there.  The attached image is showing that there are 6 instances of this block in this particular drawing.  Once I delete them and try to purge they don't show up in the purge dialog box.
Labels (1)
2 REPLIES 2
imadHabash
in reply to: NowakA09
attache your CAD dwg file and tell us your block name ?
Imad Habash
NowakA09
in reply to: imadHabash
After some problem solving, it appears we had a block dwg inserted into drawings which had no line work associated with it.  Therefore the block name was there but no image.
AutoCAD Inside the Factory
