Block Export within Boundary/Area of model space
mthomas99EQC
mthomas99EQC
Hello All,
I work for a low-voltage installer and I am looking for a solution to export blocks and their associated attribute/values within a defined area of an architectural background.
Use Case:
We place network cabinets in strategic areas of a proposed space based on a few factors. The main factor being Category cabling distance limitations. Based on these limitations, we have to ensure our network cabinets are placed in locations that can capture all data drops across the project as well as keeping those drops within a defined length of the cable run due to industry standards.
I am looking to find a solution that essentially will tie a block (data drop) to a defined network cabinet coverage area and then provide that data link within an export without having to add additional attributes to define which network cabinet a specific data drop should run back to.
Example: All data drops within Network Cabinet-A's area of coverage will export to excel/csv with that link of data automatically.
Anything existing out there to handle something like this?
@obsubahMATNDI
VincentSheehan
Would linking the Data Drop to the cabinet with a Field work?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
