Hello all,
I have an inserted title block on a layout tab (1:1 mm metric scaling for 11x17 layout ). I am currently using this entire drawing file as a block to be inserted into other layout spaces or as a template to create other layouts. The reason is because the inserted block, which only exists inside this drawing file is able to be inserted with proper scaling on other 11x17 layouts. My knowledge of scaling in AutoCAD is fairly new, even though I have tried to really understand it. I cannot edit this block, in block editor, without having it become a lot smaller and scaled down/improperly. I tried saving the block (in block editor) to another drawing and even saved it as a reference inside the current drawing. When I go to re-insert it back into even the same drawing it is scaled down for some reason.
I thought I finally understood AutoCAD scaling until I ran into this issue. I am confused as to how block editor changes the scaling of an inserted block when it is resaved. I don't want to change the scaling of the block, but I need to make changes to it. I really wanted to rename the inserted block as somehow it got embedded in the drawing with a strange weird name (A$C0DB15C09).
If you would like me to copy the drawing here I can, but figured you could help me out with this problem without needing to. Thanks in advance.
