Anuncios
Block editor renames the name of the block in block edit in place
nadiakBMNJ6
nadiakBMNJ6
Hi
I have an issue where every time I edit the block in place and hit save it renames the name of the block to whatever name I have + an integer. For example I had a block named "Downhill3L" and AutoCAD renamed it to "Downhill3L1"; "Downhill3L2".
Is there a system variable causing this or?
Thanks.
0 Me gusta
Responder
293 Vistas
2 Respuestas
Respuestas (2)
imadHabash
I suggest to check that your CAD version is full updated from your Autodesk Desktop App .
Imad Habash
0 Me gusta
cadffm
Sounds you arw using another program, like DraftSight (but then you would also ignore the warning).
I didn't know that AutoCAD does it too!?
Hmm.
It is a dynamic Block, BEDIT works fine, right.
Share a sample DWG please.
Sebastian
0 Me gusta
