Block dim from meter to millimeters
Hi all,
In the attached drawing, I had created the block numbered from 66,67,68 so on...in a meter template initially, later I copied the blocks to a millimeter template(the attached drawing itself) and had scaled the blocks up by 1000 times.
The edit blocks in place shows me the correct units, however in the block editor the dimensions are still shown in meters. Is there a way where I can maintain the consistency in the blocks and maintain the scale as 1 in all the three co ordinates and the block would show dimensions in mm in both edit in place and block editor without exploding and renaming and creating the block all over again, Thanks in advance!
