Block Dilemma
cs2kplus
Block Dilemma
cs2kplus
Once again....casual user here.
I am trying to move text in the block editor for my bom. I managed to move the column lines. I'm basically adding another "X" column to the right and shifting everything over. The 2 rows are different blocks "b1" and "b2". I open up the editor and not matter where I move the text it does not move after I save the block. What the? See attached picture and block.
WayneF
pendean
Community Legend
Community Legend
Share that portion of your DWG file please.
cs2kplus
I added attachment to my original post. Thanks!
pendean
Community Legend
Community Legend
Thanks.
You could just grab those attributes (smart text in blocks are not called "text"), and move to where you want
or better yet, why not just insert that block again: your edits will show up just fine. ADDSELECTED command is right there in your right-click menu
By the way: this attribute is set to be center-justified, but it appears you prefer it to be left-justified, fix that when you edit the block again
cs2kplus
Sorry for getting back so late. This looks good. I am not sure what the add selected command does.
Are you saying edit the block then reinsert it as opposed to it dynamically updating?
vinodkl
Hello @cs2kplus
I haven't look at the drawing, but I can confirm that the attributes position changed inside the block editor will not reflect outside the block editor until its synced. After updating the attribute close the block editor and use the command "ATTSYNC" and select the block and press enter. Now the attributes will sync and reflect the changes🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
pendean
Community Legend
Community Legend
