Hi All,
The block count tool that has been introduced in the 2022 version of Autocad was almost perfect for some of the data extractions I was looking to do. I basically wanted to get block counts for specific selections of blocks to put into a table. However it appears that its not possible to perform the counts on a selection, it only seems to count the blocks on the entire model space, then down to the user to check/uncheck what they want included in the table or not. I'm currently using the data extraction tool which does what I want it and allows you to select what objects are included. However the block count tool is far quicker, and If I could find a way to allow it to count by selection it would be perfect. Does anyone know if this can be done? I'm currently using the Full version just for the data extract tool, if I could make this work with the block count tool, I would only need to use LT which would save lots of money every year.
Any help is appreciated.
