Block behaviour odd once constraints are added
Hi all,
I am having an issue with constraints when I apply them to blocks in a drawing with a UCS.
When I insert a block into the drawing, I am able to manipulate its position relative to the UCS and current position. As soon as I add any constraints to the block, and try manipulate it, it seems to move relative to the WCS.
For example: the UCS is set at 47°, when I move the constrained block (only one constraint at this point) the cursor shows that I am moving at 90°, but the block actually moves at 137°.
If you also want to move this block from one point to a snap on another object, the block doesn't move relative to the cursor, but at some, seemingly random, ratio between the relative selection point and the distance being moved.
I can't seem to find anything that helps me figure out what is going on here...
Has anyone had this issue / or knows what it is?
Neill
