Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Block attributes populate in wrong order
Hey Guys
I have a title block that we insert in to drawings. In BATTMAN they are all in the right order, but when we insert the block and edit the atts with EATTEDIT the list is reversed.
Does reversing them in BATTMAN fix this?
Correct order (BATTMAN):
Wrong order (EATTEDIT):
anyone?
M_Hensley
Did you hit the sync button in battman to apply the settings to all block definitions?
Tried it, see screencast below
thisispreston
Hey,
I had this problem a while back, except for me it wasn't reversing the order, it just wasn't bringing in the attributes at all.
I know it's not an ideal solution but the way I got around was to open the drawing where the original block is and then just copy and paste it into the drawing you want to use it in, the problem seemed to only occur for me when I was using the INSERT command.
Like I said, it's not ideal, but got the end result I wanted.
Hope that helps a little!
"music is my religion" - Jimi Hendrix
