Block attributes linked to look up table - not working
No aplicable
Hi All, Wondering if you can shed any light on the below. I have a block with a number of attributes attached to it. I have inserted specific look up tables in each attribute value by 'insert field' and following the steps. It has been working fine so far, but I have come across a problem in one drawing. When I update the attribute value by selecting one of the options from the look up table, even after I regen, it doesn't update the actual attribute value. I have checked that the look up table is still linked to the attribute (as in someone hasn't overridden or deleted the insert field) and all is OK there. If I copy the same block into a different drawing and change attribute entries there and regen, it works. If I copy a different block with the same attribute and look up fields into the drawing Im having problems with, and try altering the attribute entries using the look up fields, and regen, it doesn't work. This obviously means there is nothing wrong with the block, but something to do with the file/specific drawing itself. Can anyone give some advise how I can fix this issue in the drawing? I'm afraid I cant upload the specific drawing as it is work related and I am not allowed. Thank you
0 Me gusta
Responder
392 Vistas
2 Respuestas
Respuestas (2)
MMcCall402
A couple things to try:
Manually run a field update with the UPDATEFIELD command.
Re-sync the block attributes of the inserted blocks with the block definition:  ATTSYNC
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
0 Me gusta
No aplicable
Hi
Thanks for the answer!
I had tried Attsync already and doesn't work.
I just tried updatefield command which also doesn't work :cara_de_decepción:
0 Me gusta
