Block Attributes conflict
chakra48
chakra48
I have received a structural file the column values shows correct but when i convert into block the Tag got changed bcoz they made Attributes. I have enclosed the screenshot and cad file also. Pls help me how to do it. what i want once convert into block, the tag name should not change
0 Me gusta
Responder
Soluciones aceptadas (1)
470 Vistas
4 Respuestas
Respuestas (4)
cadffm
Send it back and wait for the fixed version.
The creator (if he created all inside this file) used Attributdefinitions instead of Text or MText.
A common mistake of beginners, specially if they found blocks and used explode,
because they don't know what they doing - or what thes sould have to do (refedit/bedit or in special situations burst).
After this step, they using the tag names of attribut definitions "accidentally"
Sebastian
0 Me gusta
pendean
Community Legend
Community Legend
@chakra48 That attribute has a default tag, and that is
you simply need to either change the default before you create the block or manually enter the TAG you desire after you create the block.
0 Me gusta
cadffm
>>". what i want once convert into block, the tag name should not change"
This sounds that you are the one who wrote "C1" "C2"...
Sebastian
0 Me gusta
paullimapa
Solución aceptada
Your structural CAD file was incorrectly done with ATTRIBUTE DEFINITIONS
They should have been TEXT objects.
I used this handy A2T.lsp to convert all of the ATTRIBUTE DEFINITIONS to TEXTS and that should solve your problem (see attached).
Paul Li
IT Specialist
@The Office
