BLOCK ATTRIBUTES COMBINATION
No aplicable
Hi, experts
I am creaing a block with 3 attributes, I just want the 3rd attributes get the values of previous 2 attributes, I insert the fields into the 3rd attributes value then concatinate the previous 2 attributes values, after inserted those blocks, I just snychronize the blocks but the 3rd attributes cannot updated;
if there any advice regarding this issue?
thanks a lot in advance;
0 Me gusta
Responder
635 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
while you are in block-editor and use command _ATTDEF to define your attribute make sure the checkbox "Display value for block reference" is activated!
Look to the video which shows the complete workflow, I also attached the modified dwg-file.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
Thank you very much, I will try it out a little bit later.
HTH, - alfred -
0 Me gusta
