Block Attribute
tim.ainsworth
Block Attribute
tim.ainsworth
Wondering if there is a way to set an attribute in a block, or dynamic block which has a set length, without using fit, and cand wrap the text into a multi-line while resizing at the same time. I'm currently not aware of one which enables you to click on the block to enter text without going into the field editor.
Regards.
0 Me gusta
Responder
241 Vistas
2 Respuestas
Respuestas (2)
vinodkl
>>I'm currently not aware of one which enables you to click on the block to enter text without going into the field editor<<
Have tried holding down the ctrl button and then double click on the attribute to edit then in place?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
R_Tweed
There is a multi-line option for attributes.  When you define the attribute, you can set the width/1st line length at that time.
0 Me gusta
