Block Attribute Text Extraction.
No aplicable
When I insert a field in my multi-text object that is being pulled from an attribute on my titleblock, the field is surrounded by a gray box.  Is there anyway to change that so it appears as just regular text?
0 Me gusta
Responder
Soluciones aceptadas (1)
926 Vistas
4 Respuestas
Respuestas (4)
Alfred.NESWADBA
Solución aceptada
the grey background is just for the display, so you can see that this is a field value, it is not printed.
If you don't want that you can turn off FIELDDISPLAY (>>>details<<<)
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
@Alfred.NESWADBA's great answer is absolutely correct.  The field background is displayed so that you know the text is not a piece of Mtext but that it is a field.  It should not affect formatting or printing.
John Vellek
0 Me gusta
No aplicable
Perfect.  I also learned that there is a command, UPDATEFIELD, that will update text on selected objects or depending on how the FIELDEVAL variable is set, running a REGEN command will update the all the MText that contains field data.
john.vellek
HI @Anonymous,
Right you are. I hope that the feature proves useful to your work flow.
John Vellek
0 Me gusta
