Message 1 of 14
08:55 PM
In creating various blocks with attributes (a Line with an Attribute inserted at the midpoint) I noticed that some attributes, after being attached to the block, moved to a completely different position than the one I'd assigned in Attdef; whereas others stayed where I'd put them.
As far as I can tell, there is no difference between those blocks that could explain the displacement. What could have happened?
I've attached an example. The first 3 blocks are normal, the 4th's attribute moved there immediately after being attached, even though it had been under the line's midpoint like the others.
