Block Attribute Insert Issue
HAS140
Message 1 of 8
HAS140
I have a simple block attribute that recently has stopped working. It is set to insert at 0,0 on the layout tab on my border sheet. It will only show if I select "explode" in the Insert dialog box which of course removes the editable function. I can, however, copy the block from a last know drawing where it inserted properly and paste into a new drawing and it works just fine.
ATTDIA is set to 1.
ATTDISP is set to normal.
ANNOALLVISIBLE is set to 1.
ATTSYNC can't be used because the block is not inserting.
All appropriate layers are on, (root block is on layer 0).
The dwg is attached if you want to give it a shot.
Any suggestions?
Thank you.
Replies (7)
Message 2 of 8
CGBenner
@HAS140
Hi, can you tell us what version of AutoCAD you are currently working in?
Chris Benner
Message 3 of 8
imadHabash
Sorry, would you please clarify more your issue?
Imad Habash
Message 4 of 8
imadHabash
You may need to enter a Value ( for 3 attribute text) in the dialog before inserting it.
Imad Habash
Message 5 of 8
cadffm
You have to set ATTREQ on(1)
what is the default value.
read more about in[F1] help
Sebastian
Message 6 of 8
HAS140
Thank you so much, this did the trick! ATTREQ was set to 0.
Appreciate you taking the time to help me out.
Message 7 of 8
HAS140
Thank you for your time to help me out. ATTREQ setting was the issue. But I am going to make a note of your suggestion as well for future use.
Message 8 of 8
HAS140
Im using Architecture 2023. A solution has been provided, and I am back up and running.  Thank you sir
