Block/Atrributes
cameron_s
Block/Atrributes
cameron_s
Hi All,
I am currently working in a file that has 7 different page layouts, each one having a title block.  All 7 pages use the same block so when the attributes are edited it changes the values on all pages.  My question is if I want to change the values on say just "page 5" how do i make that title block independent, or edit the values independently with out exploding the title block.
0 Me gusta
Responder
Soluciones aceptadas (1)
696 Vistas
14 Respuestas
Respuestas (14)
jackshield
how are you editing now?
should be to edit the the attribute by clicking on it ...
0 Me gusta
wispoxy
@cameron_s Use command EATTEDIT (enhanced attribute editor) and set accordingly. This way you don't need to explode to edit a block.
Command BATTMAN will be usefull to manage your enhanced attributes.
0 Me gusta
cameron_s
Im sorry for my bad description...What i am trying to edit is not an attribute it is part of the title block.  I have to use the comand DWGPROPS to edit the field as it is not listed under the attributes that i can change independently.
thanks
0 Me gusta
cameron_s
thanks
0 Me gusta
jackshield
i have no idea what you are doing, perhaps post the file?
0 Me gusta
cameron_s
I cant post the file its sensitive information.  I will see if I can put together a better explanation.
0 Me gusta
jackshield
just erase everything in modelspace, all we need to see is paperspace layouts
0 Me gusta
cameron_s
Ok so here's the test file.
If i edit attributes it gives me a few options of what fields i can edit.  But if i want to change the text under "revision" or the text under "date" i have to use the command "DWGPROPS" to edit those fields.  Now when editing these revision fields it changes all the text throughout all paper space layouts.  Is there anyway to edit the revision/date text on just one layout page "SD7"
0 Me gusta
jackshield
those "fields" are just TEXT
redefine your block and change the TEXT to ATTRIBUTES
0 Me gusta
cameron_s
Is there any chance you could go into a little more detail about that process.
Appreciate your time
0 Me gusta
jackshield
Solución aceptada
Open source file that you used as your insert. Replace the TEXT entities you wish to be able to edit with ATTRIBUTES. save and reinsert into your other drawing.
Sent from my iPhone
cameron_s
Thanks!
0 Me gusta
wispoxy
Do a manual deletion of the value, but if you do it will detach it from changes with the others.
0 Me gusta
wispoxy
@cameron_s Glad to see your problem was resolved.
0 Me gusta
