Blank Sign in on two PCs- fails with System Variable changed on Third
Hello. Three Dell Windows 10 newer PC(NVIDIA Quadro P4000, 8GB, 4 DP), all worked until last night/this morning. When I attempt to start AutoCad 2020, either the blank dialog box with just Sign In appears, or just a white screen. I can see the user name- upper right corner, but when I click on it, I also get a blank box, with the autodesk- User profile at the top. When I attempt to open an existing DWG file, I get the error message " System Variable Changed" . When I view the change- it shows selection preview as the error, Prefered as 3, and current as zero, no where to change the current at this screen There is a option to reset all, but I am unfamiliar with Autodesk, so not sure what that will do.
I think it is a resolution issue with Windows 10 of some sort. Of the 4 PCs in the office, three are failing, the only one working is an all-in-one PC, with a different monitor setup then the Dells. I would call, but I am not the owner on this account, and I am having difficulty finding the Autodesk help number.
Thank you for any help.
