Bing Map Showing Old MAP Data as compare to Google earth map data
afzal.tanveer1
Message 1 of 14
afzal.tanveer1
Dear All,
Please anyone help me regarding the Bing Map in Auto cad 2021. I attached the map data using geolocation command and Map attached, but the thing is when I compare the Bing map data to google earth map data the Bing map contain very old data. so Please help me I want as google earth map data in my Auto cad file.
Replies (13)
Message 2 of 14
TerryDotson
Bing has a tendency to be more out of date than Goo' and even GE is likely to be out of date compared to the imagery available from your local / state government agencies, as is the case where I am.  Research your government GIS resources, chances are you will find better imagery there, and assuming your drawing file is *truly, properly* geolocated, then you can reference those images into your drawing with a world file, etc.
Message 3 of 14
rushabhthakkar_910
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/BING-m...
Sometimes switching to Birdseye may improve the resolution. It's possible that the higher aerial imagery hasn't been updated or hasn't been captured by the BING team. This is something which is beyond the control of Autodesk.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 4 of 14
Pointdump
Rushabh,
"...switching to Birdseye..."
I looked at your link, but have no idea what "Birdseye" is. How do you "switch"?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 14
rushabhthakkar_910
I know we should test whatever we share. But I was just going through a few links. And thought maybe this could help OP.
I also found this..
How do you get birds eye view on Bing Maps?
You recently changed access to the Bird's Eye View in Bing Maps from the dropdown box to right-clicking the map. When I right-click the map and click on "Bird's Eye View"from the context menu, all that happens is that the "Road View" zooms in.
Thanks and Regards,
Rushabh Thakkar.
Message 6 of 14
afzal.tanveer1
I tried but nothing happen same as areal map images
Message 7 of 14
afzal.tanveer1
I am sure that my drawing is properly geolocated. I am just locking for solution to add the Goo' map data except Bing
Message 8 of 14
rushabhthakkar_910
Click on the Insert Tab in the Ribbon and then in the “Set Location” Panel, click the icon that looks like a globe. A drop-down will open. Click From Map. (In the future, a quicker way to accomplish this same task is to type GEO into the command line and hit ENTER twice.)
https://birchlerarroyo.com/autocad/how-do-i-embed-a-google-map-in-autocad.html#:~:text=Click%20on%20...
Thanks and Regards,
Rushabh Thakkar.
Message 9 of 14
vinodkl
Hi @afzal.tanveer1
AutoCAD only provides Bing maps. You can try this trial app to import Google maps.
What I do is take a snap from the Google maps and attach it as an image into AutoCAD and scale it as per the measurement which was taken from the google maps and start working on it 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 10 of 14
AllenJessup
I do what @TerryDotson suggested. Try to find higher quality aerials from local sources. We're looking into contracting with a vendor like NearMap to supply more frequent updates.
You're not going to be able to insert Google data directly into AutoCAD without a third party app.
Allen Jessup
CAD Manager - Designer
Message 11 of 14
TerryDotson
... looking into contracting with a vendor like NearMap to supply more frequent updates.
NearMap also has a nice tile server system that (given the right tools) you can simply window your area of interest and build a high resolution image inserted into your geo-referenced drawing (and automatically draw-order sent to the back).
Message 12 of 14
AllenJessup
@TerryDotson
That does sound nice. But being a municipality we need to get proposals from multiple vendors and evaluate them. We may need to drop some bells and whistles to stay within budget. But the process is just getting under way. So we'll see. Thanks.
Allen Jessup
Message 13 of 14
You can use the Plex-Earth Lite free add-on from App Store to see Google earth images in AutoCAD:
https://apps.autodesk.com/ACD/en/Detail/Index?id=2341755195508345379&appLang=en&os=Win32_64
Hope this helps!
B.
Message 14 of 14
afzal.tanveer1
thanks a lot
