Bind xref drawings into one
jbaflyer
Message 1 of 10
jbaflyer
I understand about binding and how it works, but it is not really what I want.
I need to take multiple xrefs, combine them, and then have all those entities pasted into a new drawing with no xrefing.
I can bind the drawings, but all the data, etc. follows it.  Essentially it is a floor plan, and I want it brought over as a stand alone file, and binding does not work for this task.
Is there any other way to export and convert for what I need?
Thanks for any help.
Replies (9)
Message 2 of 10
john.vellek
Hi @jbaflyer
Does an Inert Bind not do this for you? Perhaps i misunderstand what you are trying to do.  Are you trying to bind just the xrefs into a single file separate from the Master?
John Vellek
Message 3 of 10
jbaflyer
What is happening is I bind the xref then it is a single entity in the
drawing.
What I would like to do, is copy the binded xref with crtl-c and paste it
into a new drawing as a non-binded entity.
Brian
Message 4 of 10
john.vellek
Hi Brian,
When I select the Xref(s) and then Bind I have the option to Insert. When I select it I end up with blocks of the previously xreferenced files. I can then copy them and paste into a new drawing.  Is this what you are trying to do? if not, I apologize. Friday afternoon and all that 🙂
John Vellek
Message 5 of 10
jbaflyer
John, thank you for your help.
I am following your steps exactly and everything works until I paste into a new document.  When I paste the only object brought in says: Xref .\(file name).dwg   No bound entities are copied and pasted.
Thank you,
Brian
Message 6 of 10
john.vellek
Brian, I am sorry that didn't work. Is it possible to zip up your files and send them to me at [email protected] or attach them to a post?
John Vellek
Message 7 of 10
jbaflyer
I should have attached this.  Here is the e-transmit of what I am working with.  I would like to combine the floor plan, put it on a single layer and screen it 50%.  It is getting it to a single layer that is the problem.  I have many many floors in many many communities I have to do this, so I do not want to have to work with the xrefs.
Message 8 of 10
john.vellek
Hi @jbaflyer
Because the A-FP62 file had nested Xrefs it didn’t like being bound. So I opened it and bound all the nested Xrefs. I then removed the few that weren’t present.  Then I saved and closed it. I went back into your 2nd floor master and was then able to bind the XREF with an Insert Bind.
John Vellek
Message 9 of 10
jbaflyer
John, Thank you so much. You have no idea.
So to understand correctly, the A-FP62 file needed to be opened separately, then saved and closed.  Then when you opened the flooring layout file, you could bind and insert.
I would have never had thought of that.
Thank you.
Message 10 of 10
BINDTYPE 1
