AutoCAD Forum
Beginner Question: fillet and angles of lines
3 REPLIES 3
1172 Views, 3 Replies
Hi
I have a very simple question (started with AutoCAD yesterday):
how can I exactly redraw this part shown in the attached fig?
I do not want to calculate the length of the lines using trigonometric functions and then use the fillet function with a radius of 2.5. this would not be accurate.
How can I get the 45° degree line and 2.5 radius fillets without knowing the length of the 45° line and only the points where the bending of the corner starts?
3 REPLIES 3
parkr4st
one way is to layout with construction lines, three lines and the arc, fillet, offset and mirror
you'll get others
dave
nestly2
If you use CIRCLES where the FILLETS/arcs will be, it's easier to visualize and construct.
in reply to: nestly2
Thanks a lot! Problem solved.
Forma Design Contest
