AutoCAD Forum
Beginner Q: Accessing Library
6 REPLIES 6
766 Views, 6 Replies
I've watched a few tutorials, I've googled the issue, but I can't for the life of me find the .dwg files that my go-to tutorial uses. It just mentions "you can get this from the library"...but how do I access the library? Or maybe I need to download these particular .dwg files from somewhere?
Help is appreciated.
6 REPLIES 6
cadffm
you know much more than us!
1. You know the software used, we don't.
(share a picture of the dialog, command: ABOUT)
2. You know the tutorial, we don't
(share a link to the tutorial)
Sebastian
rkmcswain
This is probably not the answer you need, but it may be helpful to know there are some sample AutoCAD drawings here.
R.K. McSwain     | CADpanacea | on twitter
pendean
Ask the Tutorial authors 🙂
in reply to: cadffm
1. I'm using AutoCAD 2021. (Sorry, I'm getting an INVALID POINT response after entering ABOUT.)
2. I'm watching a super-basic LinkedIn tutorial, which is paywalled. (Not using AutoDesk tutorials bc I'm ultimately interested in AutoCAD electrical, and those tutorials require Revit, which I don't have.)
Thanks!
in reply to: rkmcswain
Thanks, I knew I saw mention of this page somewhere, but I haven't been able to find it!
pendean
1. Looks like you have a program problem, fix it with a reset or reinstall soon.
2. Ask the author of the paywalled tutorial, you are paying, so they should be advising on where to get their tutorials content.
HTH
AutoCAD Inside the Factory
