Begineer's enquire>> Floor [tile]
Hi All,
What is the best way to draw the box like this? I tried to copy and paste the box but how can make the red lines are stick together.
100 Long x100 Width boxes
After I make the red lines, what is the steps to put the yellow boxes inside the red boxes?
imadHabash
There are many ways :
  • draw one box then use ARRAYRectangular ) .
  • draw one box and start use COPY command and with proper OSNAP
  • Start draw lines with LINE command and start OFFSET those lines .
Imad Habash
imadHabash
Just prepare one box with red line and the yellow one then start Array or copy for it .
Imad Habash
Thanks, Imad
Sorry I don't have skill use osnap, or offest.
May I confirm if the follow steps can be done what I needed?
1. Create red line box(bigger)
2. Create yellow box and fill color.
3. Put the yellow box in the middle of red line box
4. Select both boxes and use "arrange " function copy many boxes.
Is that OK?
imadHabash
Please ... Click on below image to see how Array will help you 🙂
Imad Habash
Kent1Cooper
You could also do the red grid as a Hatch pattern, but not the yellow infills, so for those you would still want an Array.
Kent Cooper, AIA
