BATTORDER is Less Than Expected
sbrusco
sbrusco
Hi All,
I know i've lost the weekend but have i also lost my mind?
I'm in the block editor and trying to use the BATTORDER command to, you guessed it, set the order the attributes will be prompted for when i later use the EATTEDIT command to fill in values for the attributes. While BATTORDER command seems to put the attributes in the correct order, they are in reverse order when i use the EATTEDIT command. So i reversed them with BATTORDER but EATTEDIT still prompts in reverse order.
Is it Monday? Is it me? Or does the BATTORDER command leave a person wanting?
Sal
murray-clack
Have you tried using the ATTSYNC command after leaving the Block Editor?
sbrusco
Oops! My bad. I did not but i'm sure this would solve my dilema.
Thanks.
PS. Sorry Autodesk for all my colorful thoughts.
