Anuncios
Bath floor hatch
Bath floor hatch
No aplicable
Bath floor hatch visible thorugh toilet block , how to insert without affecting block (not visible in block)?
Thank you in advance.
0 Me gusta
Responder
Soluciones aceptadas (1)
3.490 Vistas
16 Respuestas
Respuestas (16)
Kent1Cooper
Do the floor Hatch with the toilet already drawn.  [That assumes that the outermost boundary of the toilet Block is a closed  shape, so that the Hatch doesn't "bleed" inside it.]
Otherwise, you could use Wipeout(s), and use DRAWORDER to place it/them behind the toilet but in front of the floor pattern.
Kent Cooper, AIA
0 Me gusta
imadHabash
i suggest to make your toilet block as a dynamic block and set up a new Visibility state . >> Click <<
Imad Habash
0 Me gusta
murray-clack
I would suggest creating a Wipeout within the toilet block definition.  This way, if the toilet needs to move, the wipeout hides the tile accordingly without actually affecting the hatch pattern
0 Me gusta
No aplicable
Thank you Kent, Imad & Murry,
The block is created by my instructor  (by  the way I am a student). I have to insert it in my drawing. I never used wipe out and wondering in this block it will work or. I will try but I need to submit before 5:00pm ET toaday.
0 Me gusta
No aplicable
Please find pic for more clarification to answer
0 Me gusta
Kent1Cooper
The tank part is  obscuring the Hatch pattern, or if the Hatch was drawn with the toilet already there, by picking out in the floor area somewhere, then the tank part [only] is truly closed and has kept the Hatch out.  If the latter is the case, then I suspect the toilet Block's other parts have a gap  somewhere that's letting the Hatch pattern bleed inside.
Kent Cooper, AIA
0 Me gusta
No aplicable
Hatch created later.
0 Me gusta
Kent1Cooper
Then see the last sentence in my previous Reply.  Try Inserting that toilet in an otherwise empty drawing, then try Hatching inside some part of it other than the tank.  It will probably not succeed, and you should see little red circles where there are gaps in the enclosing content.
Kent Cooper, AIA
0 Me gusta
No aplicable
Hi Kent,
Thank you for your response but unfortunately it didn't work.
Regards
0 Me gusta
vinodkl
As others suggested try adding wipeout inside the block. If your not sure of how to do that, attached the block so that I can help you out with that.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
No aplicable
Please find the attachment
0 Me gusta
vinodkl
See the attached drawing. If you see hatch on top of the object use "DRAWORDER" and send hatch to "back".
0 Me gusta
Kent1Cooper
Solución aceptada
I think the problem is with the back edge of the tank coinciding with the wall line, potentially causing confusion about the boundary.  Toilets don't go smack up against the wall, anyway.  I pulled it out an inch, and the Hatch corrected itself in relation to the toilet:
Kent Cooper, AIA
0 Me gusta
No aplicable
Thank you Kent and other you responded to me.
Reagrds,
0 Me gusta
No aplicable
Sorry Dear not working at my end!!!
0 Me gusta
No aplicable
Pl find pic
0 Me gusta
