Batch Plotting with Adobe PDF to Single Sheet PDFs
daniel.welchLFHPQ
Message 1 of 8
daniel.welchLFHPQ
I'd like to batch plot my sheet list with the plotter named in page setup (in my case Adobe PDF Converter) and I want to plot them as single sheet pdfs.  However, whenever I choose publish to "plotter named in page setup" I loose the option to check or uncheck the multi-sheet file under "Publish Options..." and it seems to default to a multi-sheet pdf.
Does anyone no how to plot to single-sheet pdfs with the Adobe PDF Converter plotter?
Replies (7)
Message 2 of 8
paullimapa
Since you're not using one of the built-in pdf drivers from AutoCAD there may not be a control available on this 3rd party printer. Any reason for now using the built-in ones like DWG to PDF.pc3?
Paul Li
IT Specialist
@The Office
Message 3 of 8
daniel.welchLFHPQ
If you use one of the built in ones then when you view it with Adobe's default rendering settings (smooth line art) it looks bad.  We have a client that doesn't want to change their Adobe settings.
Message 4 of 8
cadffm
greyed out means: Not available!
So it use single page ONLY.
And this is what you want..
Q: Does it create one PDF with multi pages, or multiple one page PDFs?
Sebastian
Message 5 of 8
daniel.welchLFHPQ
The greyed out "Single-Sheet File" only says that because that's what I had it set to the last time I had the plotter override set to PDF and was able to adjust that setting.  If I had multi-sheet file selected before switching to "use plotter in page setup" then the greyed out portion would say multi-sheet file.
No matter what the greyed out area says it still plots a single pdf with multiple sheets.
Message 6 of 8
cadffm
ahh,
for usual peoples having the opposite problem.
In your case, it creates one Multipage-PDF now, okay. That's uncommon and not under controle of AutoCAD.
It sounds the Adobe PDF Converter  is set up to collect / Autospool multiple printjobs to create one multifile PDF.
I will run a quick search for you, because I am not familiar with this 'Adobe PDF Converter ', IF I  find some informations, I will post again.
But if you don'T want to change the setting, I don't know how to change that
Sebastian
Message 7 of 8
pendean
Community Legend
Community Legend
@daniel.welchLFHPQ wrote:
...No matter what the greyed out area says it still plots a single pdf with multiple sheets.
This choice of yours means AutoCAD will never ever give you control to do anything like that: only your chosen driver settings can do what you want (if it can, looks like you opted for one that does not perhaps)
Message 8 of 8
daniel.welchLFHPQ
I found a way to achieve the result I was looking for.
By changing the PUBLISHCOLLATE system variable to zero it prints each sheet as a separate print job thus creating multiple pdfs with a single sheet.
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-2369EDF8-FC5E-4DB9-8DBA-E1997C31BDED
Thank you for your help
