Batch Plotting error
Hello CAD master's ,
I have AutoCAD LT 2014 an runs in my old pc. I want to batch plot all of my drawing in paper space but it made an error. I have attached a screen shots. On error 1 attachment if i hit ok i can still convert and save it to my folder.
(As of now i'll be able to convert my drawing to pdf by plotting one by one)
But, if i can resolve this thru batch plotting which is more convenient than plotting one by one,
then i need your help..🙏
Thank you,
vinodkl
Set BACKGROUNDPLOT to "0" and then publish. Anything better?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi, can you send me screen shot pls ? Thank you
vinodkl
Type in the command "BACKGROUNDPLOT" and set it to "0". Now try to batch plot.
Hi, Still not working,
vinodkl
After check the " publish window" I could see you have not selected it to publish to PDF. Click on the option below "PUBLISH TO" and then select PDF as shown in screenshoterror 2~2.JPG
Vinodkl, now it's all good, your skill is awesome. thank you 😎
