Batch plotting areas in Model Space
Can any kind soul shed light on how to batch plot predefined areas in Model Space?
I have attached a sample drawing.
In the drawing, I have some boxes representing individual A2 sheets and I want to plot all of them one by one as pdf?  Are there any good ways of achieving this?
Thanks for your help!
leothebuilder
This may not be the answer you want, but I believe it would be easier to have multiple layouts in paper space and together with proper page setups it would be a breeze to batch plot simply by right clicking the layout tab(s)
Batch plotting from model space is possible but it would take a lot of time to "write" all the x and y coordinates for each A2 sheet into a script.
I have come up with this script:
LIMITS
0,0
594,420
-PLOT
y
model
dwg to pdf.pc3
ISO full bleed A3 (420.00 x 297.00 MM)
Millimeters
l
N
l
F
c
Y
acad.ctb
Y
A
N
Y
However, this would just let me keep printing and replacing the last pdf.  Any way to specify the file names so that they do not get replaced each time?
Also, I would prefer to stay in model space as it is easier to navigate and see relationships between drawings.  I guess i could set viewports for every position in model space though
jackshield
could you use the view command to establish named views?
the possibly farm out those names to fileenames?
How do I go about using the view name for the file name?
leothebuilder
I would keep the setup you have in model space so you can keep seeing the relationship between drawings.
Just use paper space for plotting.
By the time you figure out a script that works for you, with paper space layouts you would have finished by now 🙂
