AutoCAD Forum
Batch Plot to PDF
2 REPLIES 2
1104 Views, 2 Replies
Batch Plot to PDF
Recently upgraded to Autodesk AutoCAD2017 and it would not appear possible to batch plot to PDF. Anytime this is tried the following error appears 'The plotter configuration cannot be used for one of these reason: the present cannot be found, the device cannot be found, or the driver has a problem.'
Any suggestions how to resolve this batch plot error?
2 REPLIES 2
Cadologist
We ran into this issue when we upgraded to 2017..... the PDF driver (Autodesk) was updated in 2016 I believe and now includes 4 separate PDF files:
  • AutoCAD PDF (General Documentation).pc3
  • AutoCAD PDF (High Quality Print).pc3
  • AutoCAD PDF (Smallest File).pc3
  • AutoCAD PDF (Weband Mobile).pc3
What we had to do to resolve this was first COPY and RENAME (one of the above) to the previous file naming convention for the driver (i.e.: DWG to PDF.pc3). Next you need to ensure the four PC3 files shown above are also in the same folder as your existing PDF driver. Try to batch plot again...
There may be other solutions, this is one that resolved the issue for us. For more information, a similar link posted in the past is below with more info.
https://envisioncad.com/autocad-civil-3d-tip-how-to-fix-device-not-found-error-when-batch-plotting-o...
Chad Franklin
Alfred.NESWADBA
Have you tried command _PLOT with the driver that was listed as missing?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
AutoCAD Beta
