Batch Plot Not Working through SSM.
ruben_sumayaQ6U7Y
ruben_sumayaQ6U7Y
Batch plot does not work for someone in the office but it works for me (same project and ssm).  We are set up the same.  What am i missing?
pendean
Community Legend
Community Legend
What does "not work" mean in more detail please? There is almost always a pop-up or error message at the expanded commandline or something. Dig deeper. Your post is too light on the details as written.
Also confirm you both are using the 100% identical drivers (name alone is not going to cut it), destinations (plotter or port or drive/folder) and they have background publishing turned off too.
ruben_sumayaQ6U7Y
pendean
Community Legend
Community Legend
@ruben_sumayaQ6U7Y wrote:
good point.  please see further discussion in link:
 https://forums.autodesk.com/t5/civil-3d-forum/batch-plot-not-working-through-ssm/m-p/12518302#M50617...
Thanks for the link to the earlier discussion: so C3D2022 is not new. Is it new to both of you today?
Or first time you both jumped into SSM and Publishing today?
Or get new PCs just recently?
Are both C3D 2022s up to date
have you seen this from Autodesk
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/ERROR-Error-when-p...
From your other post, these locations/drives do not match
 what is this other location? Why is this one different from the one above
What about this other tip from the other post about missing content
If both setups are 100% identical and both of you have background publishing turned off, you'd not be seeing these types of issues using the same tools.
A reset of C3D or do-over on the other PC (remove and reinstall all things Autodesk or a new admin login for that user) may be the ultimate fix, but that's hard to tell with the info provided so far.
ruben_sumayaQ6U7Y
@pendean,
I have logged on to my colleagues pc and I am able to batch plot with the same civil 3d profile.  I am at a loss... I will reinstall Civil 3d on his PC...Thnx!
