Batch plot default file path
jc.zamora.29
Message 1 of 10
jc.zamora.29
Hi All,
Is there a way, that when you batch plot, the file path of the pdf automatically saves on the folder of the .dwg? Our current cad setting automatically redirects to a filepath that nobody uses and we have to save the pdf file on the folder of the .dwg project so we have to search for the file path of the .dwg everytime we batch plot. Im not sure if this is the default setting or somebody tweaked it? I tried changing the reference path for the plot and publish log file location but it can't be set to a "variable" file path. Can anybody help me with this? Thanks in advance
Replies (9)
Message 2 of 10
vinodkl
Try using "AUTOPUBLISH"
More information : AUTOPUBLISH (Command)
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 10
jc.zamora.29
Sorry, AUTOPUBLISH doesn't get what i want
Message 4 of 10
vinodkl
Hi @jc.zamora.29 ,
May I know what is not working for you when using "AUTOPUBLISH". Have you checked the Automatic publish settings in option, were in you can control what to include in plot and the location of the published pdf?
Message 5 of 10
jc.zamora.29
Sorry, i might not explained it thoroughly, but i think there isn't a option for autopublish to select the pages needed for printing?
Message 6 of 10
maratovich
Like this ?
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 7 of 10
jc.zamora.29
Thanks! I'll try this one, may i ask where these settings can be found? also is there a setting for autopublish to ask if you want to override the pdf before plotting?
Message 8 of 10
maratovich
This is an add-on for AutoCAD : Revers
Show an example of your file with the title block and specify how to save it.
I will make an example.
www.kdmsoft.net
Message 9 of 10
jc.zamora.29
Ohh i'll look into this. Thanks for your time! autopublish might do the trick for now.
Message 10 of 10
risolaNG4VF
Found what we were looking for, under Batch Plot → Publish Options → Location
Unfortunately you cant set it to current folder so I just put the generic job directory.
